Flares again
tjanna
1 Sep 2012
Farnham, Surrey
Lucky me! I have inherited a considerable amount of 25 year + old flares with my boat purchase from end of the last season, these had been kindly stashed away in the bottom of the boat. It appears you have to jump through hoops to legitimately get rid of these damn things, quite frankly I have better things to be doing with my time.
My cunning plan is to encase them into a concrete mix, either in a bucket or box. When set, simply bury them along with my wifes ageing 19 year old cat in the back garden. Two birds with one stone:eek:
Is this a feasible plan or am I missing something?
Thanks Gareth
Think of the archeologists of the future who will have to work out what weird ritual was being carried out.
overheard two guy's talking about getting rid of out of date flares. One said he dumped them in deep water while the one said he 'let them off' into the water.
Now there's a thought - how about dumping somewhere like this instead of burying:
Thanks Gareth
I wouldn't enclose suspect pyrotechnics in a gas tight-solid object unless my intention was to make them go bang instead of ffft. Particularly if it was concrete which could get a bit warm when hydrolysing.
Digging a hole and putting a paving slab over the TEPs then refilling the hole might work, especially if a hose pipe was used to consolidate the soil. The cat would be optional but I would recommend welding gauntlets if including that.
local council explosives 'expert' said put them in a large bucket of water and leave for long time.(i.e. 3 or 4 days) The explosive will leech out then you can pour it all down the drain with lots of flushing. Don't sue me if it doesn't work
Hopefully you'd wait until the cat was dead !
I intend to dismantle some ( non rocket) out of date flares soon. They are not IEDs. I suspect they will be simple devices, the contents should burn easily.
Is your boat anywhere near a Coastguard MRCC? If so you can still arrange for them to take in the old flares, if you are prepared to deliver them.
It's also worth asking the local police, or the local Council. This seems to work in some areas.
They will be once encased in a concrete block :p
Ooh I hope no one dodgy is reading this thread, TMI ;) Anyway I am going to get out and do some work, but surely there is not enough of the oxidising chemical to provide enough brisance* to split open a lump of concrete?
*Ill-remembered technical term from mis spent youth etc
