Flaking a sail single handed.
I’ve read a number of articles recommending that cleaning the mast track is much more effective than putting more and more gunk on the slides.
I am sure you're right but do you know of any effective way of doing it without either climbing the mast or having the mast down?
Yes - get a short length of bolt rope, put an eyelet in either end so you can attach it to a halyard and to a down haul, then put it in the slot with a microfibre cloth around it.
I will see if I can find the articles.
Usual method is to get a bit of luff groove tape and send that up on the halyard.
(n.b. also rig a downhaul to get it back. Yes, I've seen it happen)
I wonder at what stage sail slides and slugs need to be renewed.
Perhaps due to wear they become semi jammed , particularly under pressure.
They are cheap to renew so I might as well do it at the same time as cleaning the track. I will also inspect the batten cars closely.
When I renewed my sails, the slugs were too big for the track. They sent smaller ones but they were a little too small, with the result that they could tilt in the track which I'm sure made things worse than the original sized ones.
Flakes? Cadbury's 99 :-)
More seriously: when actually lowering sail - bundled very roughly with two bungees. Then sort it out later when stopped, when I can do a good job without worry.
Slot cleaning / clearing - is pretty important; I made an acetal plastic "slug" that I can haul up and down that clears coarser debris very well, but the one bignick linked would be better for general cleaning.
