ChasB
I've a GRP hull, circa 1982. One of the cleats is now allowing water to seep (drip actually) into the boat and must be replaced. Someone else has obviously had a go at it once - the nuts and blots have been changed. There is a plate on the other side of the hull, and it is all held together with 4 nuts and bolts.
With anything else I'd remove the whole assembly, dig out the holes a bit, lay in some fibre glass filler, put some gelcoat filler on top, drill out new holes, and then remount the whole thing with fresh nuts and bolts (marine quality) and seal with silicone.
But this is a cleat and takes a lot of strain, so I'm worried that my approach wouldn't last long. Any advice here? /forums/images/graemlins/grin.gif
Also, I am correct in believing that this leak, and any others like it are slowly compromising the integrity of my grp hull? /forums/images/graemlins/frown.gif
That last question also makes me wonder if the grp around the cleat is now waterlogged. If so, I should dry it out first, no? How do I do that quickly?
