longjohnsilver
From what I saw it was just an amateur showing how he thought best to do a job with no real knowledge so he wouldn’t be allowed near my boat.
We all have our own opinions.........
And the answer is in the first sentence, https://en.m.wikipedia.org/wiki/Crimp_(electrical)
What was the question?
We use these tri-rated bell mouthed lugs on 3 phase power connections using 16 tonne crimpers, rather than the 8 tonne the chap was using. We routinely have to use different size jaws because the crimp terminals vary in wall thickness quite considerably, so a heavy crimp for stiff armoured cable would require the 50mm2 jaws for 50mm2 cable, but when a bell mouth crimp is used for tri-rated then dropping a jaw size is perfectly normal. He was careful how much pressure he put onto the crimp and left a small gap between the jaws, otherwise I have commonly seen the crimp extrude sideways into the minute gap between the smaller jaws, although this is harmless, and means the crimp is ultra tight, but doesn't look quite so tidy.imho
the guy in the video gave a very carefull explanation, and did a good job, but not a pro,
what he said on the crimp tool is worrying, he used a 35mil tool for the 50mil clamp,
so the crimp will be just "approximately" right,
in a pro crimp, you use the correct tool, and crimp it completely / before you can release the tool;
and there is no need to put solder.
oh yes,
solder will avoid corrosion on the wire ends, but that corrosion is negelectible in the grand sheme of things.
when a crimp is perfectly done, the mechanical contact inside is nearly perfect homogenious
we did hundreds of such crimps in mobile applications (OB vans) with a correct tool, and never put any solder inside, never ever had a problem with that.
the idea of using solder to garanty the good connection inside this high current cable clamp woud anoy me, because Tin has more resistance than copper, so could warm up when the curent gets high...
using silicone for closing these openigs is no good idea imho, silicone might not glue perfectly with the metal, so still leaving some openings for moisture, so it will give you a "false" feeling that you've done a good job.
(silicone is a product that I alway's avoid to use onboard, better use the correct type of sicaflex / 3M or perhaps tek7, depeding on the job to be done)
Because we use it at my business in vast quantities. Besides on an enclosed power boat the entire run is in very dry conditions so with well protected and properly crimped ends I am not so concerned about contamination causing corrosion of the terminals. The Tri-rated is certainly easier to handle and route around difficult places than some of the stiffer heavy duty cables with thicker and fewer strands.Can I ask why you are using tri-rated cable rather than tinned please ?
The only tinned battery cable I have used seemed a lot less flexible than untinned - but I am not certain the untinned had all 3 certifications.
my experience as well. Only used tinned cable to redo completely the bonding in the bilgesThe original cables on my boat are not tinned and apart from those running through the bilge areas for bonding I have never found any with the tell tale black oxidation present.
Well, I never thought battery cables could be so controversial![]()
A question for everyone, how many times have you suffered a cable connection failure? I can’t remember any in over 30 years of boating. I’ve changed a few for other reasons, but never because of failure.
