Yellow Ballad
One of my jobs was to fit mast conduit while the mast is down but I'm struggling settle on the best option.
I had settled on using corrugated flexible conduit with cable ties and tails but the more I think about it the more I'm thinking I may be better using 32mm PVC waste pipe rivited to the inside of the mast.
What are people's thoughts on how to fit the pipe to the mast? Rivet spacing (2m ish)? How to hold it agaist the mast whilst riviting it(mast head/cap is welded on)? I did think about laying everything out externally but I'm guessing the law of sod will means it'll not line up once inside. My other thought was drilling two holes one above the other and feeding a loop of wire through to snare the pipe and hold it up whilst it's drilled and rivited through the other hole?
I'm probably over thinking it but is there an easier/better way?
