pcatterall
I have a 'spare' 6mm forestay which had been used when our Neptunian ketch had a bowsprit. It is no longer used but I would like to bring it back into service even just for a small additional jib or storm sail. There is a good deck fitting ( just a U bolt) at a useful position just behind the anchor windlass I want to use a Highfield lever so we can deploy the inner sail quickly as needed. I am happy to shorten the stay and use Staylok type fittings for the fitting to the Highfield lever. I want to take the right gear out to Spain ( roll on!) and seek advice about just what bits I will need and the best place to obtain What parts do I need to corectley connect the lever to the U bolt. I did use the stay with the fork fitted directly to the U bolt but am pretty sure that that is not really the way to do it!
