Neeves
We also have a removable inner forestay with a Highfield lever arrangement attached to a U bolt on the deck (and the underside of this is tension down to the anchor locker bulkhead).
The outer forestay has a roller furling genoa; the inner forestay is used for a high cut yankee working jib. It could also be used for the storm jib, although we have never had to use this in anger.
We usually leave the inner forestay in place, unless we know that we will be short tacking with the roller genoa.
If only anticipating maybe one or two tacks on a passage, we simply roll up the genoa as we tack, and then let it out again on the new tack.
It is nice to have the security and peace of mind of the extra forestay.
We do the same - have an inner forestay on a Highfield lever which we leave,.effectively permanently attached. It was originally wrapped round the mast and simply looked untidy. Our inner forestay is attached to a flange on our cross beam (catamaran) - if it was attached to the foredeck behind the trampoline it would carry a very small sail.
But we are yacht owners of considerable experience, or maturity
Jonathan
