ip485
I would like to fit a Eber water heater dedicated just to heating the water in the calorifier.
The calorifier at the moment is either heated by the engine or the immersion via shore power or the Genset. The Eber will make me independent of shore power or the need to run the Genset just to heat water.
I have the following questions.
1. I think I can run the in and out water supply to the Eber into the existing pipes from the engine to the calorifier, but I assume it is probably not a good idea to pump the hot water produced by the Eber around the engine as well. Does that suggest non return valves in the system and where would you place them? What type and where can they be sourced from?
2. I have an existing Eber hot air heater. It will make fitting easier if I use the existing fuel supply. I cant see any issues "Ting" off from this supply with a metering pump in each.
