Sea Change
We're heading up to Nova Scotia this summer and I'd like to install a blown air diesel heater. I'm familiar enough with these units and have installed two on previous boats, and helped a friend install his.
I'm aware of the limitations on ducting length, exhaust length, and I'm aware of how hot the exhaust can get.
In an ideal world I'd fit the heater in the engine room or in a stern locker, and run the ducts forward. However my boat's layout doesn't lend itself to that. In typical 80s French fashion, the aft heads/shower is under the bridge deck, between the aft cabins. The aft cabin berths both have tanks underneath them.
So there's no obvious way to get a 70/90mm insulated duct run from the engine room past these obstacles, without building some sort of trunking, which would be a bit of a pain.
I could run the ducting higher up along the side of one aft cabin, possibly sacrificing the storage shelf to do so.
The other idea I had was to abandon the transom mounted exhaust, and run the exhaust up to a metal mushroom vent on deck. But then I started thinking about the downsides of that... you'd have to watch you didn't melt any halyard tails, you'd need to shut it if you expected any water over the deck, and of course open it again if using the heater.
Any thoughts? Any other ways of approaching this?
