Refueler
No, when we turned it up to test it.
Found some blurb for a Pioneer radio, wants a 15A fuse in the 'permanent' supply, that's a shitload of memory retention.
Not saying all radios are the same.
There is some ambiguity in the pin definitions of the DIN connectors that many radios/vehicles use.
I can imagine that some radios may use the permanent supply via a switching circuit. That is full power available but when radio switched off - power routes through a limiter so only a very small current passes to maintain settings. Switch on and that same power input now routes without limiter to power the radio fully.
That would be the only way I could see it working - otherwise you'd either lose all settings when you switch off ... or car battery would be dead very quick.
