steveej
Morning all,
I was hoping for some advice. I am about to buy a 1985 Hurley 22 (Ravensail 22) but having only ever chartered, have never had to worry about maintenance etc.
Once in my ownership I want to give the boat a thorough review from top of the mast to bottom. It needs new running rigging and the current rig is not set up correctly, I know I can use mouse lines, but it makes sense to get the mast down and check the windex and anemometer as the wind speed is currently not working properly.
I would also like to inspect the coach roof for mast compression as I believe there may be some.
There is a small amount of dirty water in the bilge so I will need to investigate where this is coming from, which may require checking all the sea cocks, hatch etc. The interior otherwise appears to be very dry.
The gas bottle is ancient and needs to be changed and I would like to make sure the gas pipe to cooker are sound and not a danger.
There is a little bot of sanding and varnishing that needs to be done - grab rails, tiller and companion way.
I need to learn a bit more about the electrics as there are currently two batteries with a switch, on a trickle charge from a solar panel. I don't want my instruments to go down if the batteries run out and the boat only has an outboard so does not charge the batteries.
The outboard has a remote fuel tank so need to make sure I know how all this works, how big it is and how many hours a full tank is going to last when motoring.
She could do with a full paint job, anti foul, topsides, boot top. The deck is also a bit scruffy, it already has non slip sections moulded into the GRP so can I just use normal paint on this. The deck paint in the Chandlers is non slip deck paint, does this mean there is grit in it? if so, I don't think it would be suitable.
The boat is currently out of the water at the current owners yacht club, so it is possible to do some painting. I am not yet a member, so plan on taking her to a nearby Marina for say October to March. My plan is therefore to stick her back in the water to move her to the marina, sail her around for a few weekends to work out what works, what doesn't and what needs replacing.
February / March, stick her on the hard and carry out any required maintenance ready for the next season.
By which time I hope to be a member of the yacht club, and will have geared her up with flares, GPS, charts and nav gear etc.
My question is, does this sound a sensible plan and would it be worth sticking a coat of antifoul on her now given she is already out of the water, or will she not be in the water long enough for self eroding antifoul to have eroded causing me problems getting it off in February? Is there anything else I should be thinking about.
The boat is only worth £2k. And I have worked out I will be spending about £1k on basic safety gear - lifejackets, flares, GPS, charts, compass, dinghy etc. Obviously I want to make sure she is safe and seaworthy before taking my family out on it next season (without wasting money unnecessarily on multiple haul outs etc).
Oh and by the way, is it safe to move around on the boat whilst she is on beaching legs and wooden supports? she has a long fin keel and looks a bit precarious. Any danger of knocker he over climbing up with a ladder?
Thanks in advance for any help.
