Seastoke
Hi when i get my boat delivered on thursday subject to sea trial monday touch wood,she will need fill in up with diesel of course but how do i know it does not have the bug and ruin the diesel i put in .help
Treat for fuel bug anyway.
I use Marine 16
Since getting the bug about 18 months ago, Marine 16 has cleaned the complete system and kept it clean.
i dont think i have got it well i am 99% certain i havn't but was wondering is it best to add some marine 16 when filling up anyway to stop me getting it in the future ????????
I assume the boat has diesel engine/s?
Check fuel prefilters for water/ black dust or slime.
Is the diesel clear
Does the diesel smell of anything other than diesel
If you can draw a sample of fuel from the bottom of the tank and look at it in a clean white bowl or plastic paint kettle.
If it looks ok do a seatrial and check the prefilters again after a good run
Look at Grotamar 82 which is one of the few that is fully compliant for EU Biocide regs, its a top performer and is specialy formulated for mineral diesel and biodiesel, as the latter is now in the supply chain.
http://www.echamicrobiology.co.uk/shop/grotamar82/3,16,0,0/default.aspx
One litre treats 4,000 in normal preventative use and 2,000 for decontamination dosage about £34 in the uk a litre.
After the seatrial check the prefilter Racor/Separ/Volvo Penta/Fleetguard etc and see :
How clean the element is, if its a Fleetguard or a sealed cartridge type you will have to hack saw it open ( not on the kitchen table) if there is slime or strings of gunk = bug
How clean does the fuel look, it should be clear, clean and sparkly, if it is cloudy or opaque or emulsified you have a problem
If you can use a Pella type vacuum pump and draw a sample from the botottom of the tank or the sump if it gas one and look at it in a clean white plastic container or paint kettle , do you see slime strings or water.
You can get a fuel test kit from the above website or they can test it for you
If the fuel in the tank is badly contaminated get a contractor to filter it for you of if a small ammount it may be cheaper to dump it, clean the tanks and replace it.
And above all in the future use a good Biocide fuel treatment such as the above with every filling as a preventative.
As others have said said:
