richardm47
Well my folding cockpit table has been re-varnished and will look great. But the problem is that the screws for the hinges are not secure because the screw holes are worn.
First photo shows the top of the table with 4 brass hinges which are all fine. Other photos show underneath of the table with the 2 problem hinges. You can see multiple screw holes where a PO has tried to fix the problem.
I can't use fatter screws because their bigger heads will prevent the hinges from closing properly. So I'm thinking I'll try to fill the holes up with something strong, then re-drill new holes in that material.
My question is - what filler material would you use for that job? It'll all be hidden under the table so cosmetic appearance doesn't matter much. I've got some Sikaflex 291 left over from another job but maybe that is too flexible? What would you do?
