Dazedkipper
What's the best method to fill redundant through deck bolt holes, thinking something strong because I'll be re-drilling close by to fit new hardware?
what is the deck material ? Ply, steel, sandwich, balsa, GRP, plain timber ...
I would be inclined to use polyester resin for the whole hole fill. Bonding should not be an issue if as Oldsaltoz suggests you scrape out some of the softer core amterial. You can put pigent into the whole mix to get the desired colour. good luck olewill
