cliffordpope
I tend to agree really - not worth the risk. But I have a technical query - OK, air will turn it into a bomb, but how can any air get in?
When your cylinder runs out, you turn it off. It contains only propane gas at low pressure. You get a new cylinder, connect on the high pressure pipe, connect to the other cylinder, bleed off the air in the pipe at the junction until it runs gas, then tighten. There is no air inside. You are not starting with a new empty (ie air-filled tank).
