Fibreglass Bloom
nevis768
18 Jul 2023
I've got a white bloom on a red fibreglass hull, about 30 years old. It's on a large dinghy, right down both sides, will it polish out and what's the best stuff to use.
Sounds like typical oxidation. I would use something simple like a medium cutting polish to remove the oxidation.
You may need to remove relatively large amounts of gelcoat.
On my dinghies I tend to use fine wet sandpaper.
There's normally the odd scratch which will indicate the reaining depth of gelcoat. It was pretty thick on a lot of older boats.
grades like 1000 to 4000 or so are most useful
Then get the Farecla out.
Get a cover with deep skirts to keep the sun off if you can, but waxing a few times a year will help.
Thanks all, hopefully I can get away without painting it. It's my old trailer sailer which I'm selling.
Yes you should be able to cut it back and polish it.
I have done my red hulled Sea Wych several times. Materials and techniques have changed over the years . If it is really bad consider starting off with very fine wet & dry as suggested above.
Take a look at this Farecla page. Solution list by market | Farécla.
To begin with I used a foam compounding mop on an electric drill running at a slow speed but I later bought an inexpensive sander-polisher ( Silverline) but it's worth buying good quality foam compounding and lambs wool polishing mops although the final polishing is not too arduous a task to do by hand.
Once the boot topping is done and the few touch ups where pontoon caused some nicks / scrapes during a storm ... I will have my powered polisher out to buff up the hull of the 38.
Reds are the worst, no matter what it’s made of. You could call it ‘old Ford-itis’. How many red fords of more than about 10 years are still the proper red? I’ve just repainted my wooden boat from red to light blue for the same reason.
I always hated red boats ... made me think of Gypsy Carnivals ... but this one seems to grow on you ...
But yes - red seems to be a bad colour to keep nice .. black is another.
Mine used to be a sort of plum colour. She’s kind of pale summer sky now. I didn’t mind the colour, it was just the UV damage.
Red degrades more than any other I have found. Will simple T cut polish work? A quick job if you are going to sell. A longer job needed if going to keep
T Cut - you have to be careful with as any residue from it can yellow ...
I use it though after Oxalic to remove any oxidised residue / bloom of the gelcoat. Then a going over with Cilit Bang or similar to make sure all is removed before using a liquid wash and wax ...
I see guys with polishers and wax . spending hours at it ... month or so later - not much difference between mine and theirs ..... (my white SR25).
My red Conq38 .... that actually is still quite glossy despite lack of cleaning / polishing by me. Its International Perfection 2 pack ... seems to be quite good.
Once yard has completed hull work - she will get a quickie once over and then launch. Have a rendezvous to make with a CA member over in Sweden early July ...
I managed to remove the oxidation today using 3M medium cutting compound. Didn't take long with a buffer I got from Amazon. I used a sheep wool pad, and then a polishing pad. Thanks to all for advice.
