Boo2
One thing I've sometimes wondered about is the life of the armature; it just has to rust, and salt water will get to it somehow...
Aiui, the cement provides an alkaline environment and prevents the armature from rusting.
Boo2
Boo2
Boo2
That's a very good point that I had never considered previously. Boiler water is dosed to give a pH of about 10 to control corrosion. Steel corrosion is almost non existent at this value.
I appreciate that but it illustrates how slowly ferro deteriorates, even with no maintenance and being washed by the tide twice a day. The durability of the material is evident, even if the construction details differ.There's quite a difference between the old concrete lighters and the 70s/80s ferrocement, though.
There used to be a firm building ferro-cement boats on the East Coast.
This is timely, here's a few random links:
http://www.ferroboats.com/
http://www.boatdesign.net/forums/boat-design/pictures-my-ferro-boat-advice-sought-15838.html
http://www.cruisersforum.com/forums/f47/cement-boats-4128.html
http://members.shaw.ca/petersfreeman/sports/sailing/sailing.htm
I've just bought a ferro hulled boat in Greece, she's a Hartley RORC 32, on the small side for ferro hull, she weighs about 8 tons. Mine was professionally built in 1978, has had a total refit that was completed in 2007 & for what I paid I couldn't come anywhere near a boat of the same standard of equipment & fitout in fibreglass. You'll have to accept that insurance will be difficult to obtain, FC virtually impossible so effectively you need to be prepared & able to self insure your own boat. On the test sail before I bought mine I didn't have a clue what to expect of the sailing ability of an 8 ton 32 footer but was pleasantly surprised, she will not win races but will I think make a good cruiser & liveaboard. The last of the links above includes the tale of a guy who sailed a Hartley RORC 32 weighing in at 20,000lbs (9 tons) around the world non-stop in a then world record time, so they can sail, even the little ones...
Ferro-cement boats are made with cement, not concrete.
The 'Ferro' in ferro cement is important - it overcomes the brittleness of the cement. Cement is good in compression; steel good in tension. The two work in tandem to produce a solid hull.
Ferro is very tough - certainly not 'vulnerable' to impact failure. I'd much rather be in trouble in a ferro boat than a grp one.
Buying is cheap and selling is always difficult. There are too many 'bad' examples around that de-value the 'good' ones.
Insurance can be obtained through Yachtmaster Insurance in suffolk.
As for advice in buying one? Seek out one built in the 70's / early 80's - as this is when ferrocement boatbuilding was in it's heyday - and there was plenty of experience around. Also, if it's lasted this long - then you can be sure the hull itself is sound.
Here's an interesting thought - Ferrocement is less dense than GRP...
Concrete is a mix of cement and aggregate(inert granular material). I've no idea what mix is was used for ferro-cement boats but would be very surprised if it was 100% cement - the heat of hydration would be enormous and would cause a lot of cracking when it cooled down.
The mix for FC boats contains no agregate - it is a strong cement/sand mix.
