blackfish
... so in the market for a new 2.5 (ish) hp outboard for the dinghy.
Which one would you go for?
I had the Suzuki 2.2 before my current 2.5 4-stroke. The only convenient way to pick up the 2.2 is by the movable handle, which is sort of ok for a short time but the 2.5 has a comfortable fixed handle. The 2.5 has much more poke, is more economic on fuel and no bother with mixing oil, so, unless you have a particular need for a smaller engine or one that you can throw around, the 4-stroke definitely wins for me.The Honda 2.3 is very popular, my friend has one and it always starts first time even after a winter with no maintenance.
Both the Honda and Suzuki weigh the same so try whichever is more comfortable for you when carrying. Personally I prefer a two stroke, I have a Suzuki 2.2 which is about 3kg lighter and more important(for me) is easier to carry as the powerhead is much slimmer. Good 2 strokes are still available secondhand at much less than a new 4 stroke.
Tohatsu 3.5 2 Stroke if you can get hold of one.
the little air cooled Hondas have been very good starters
They are like lawnmowers and run on a minimum maintenance regime
Fresh fuel, plug change once a year, oil change when you feel like it.
Air cooled is good because no gubbins getting sucked through the cooling areas, no impeller to worry about and should they come out of the water then no worries for a minute or two
I like the centrifugal clutch and has never given me any problems
Sadly rather too many mild steel components inside so there are lots of bits that go rusty over the years - which is a bit annoying.
As said above - they are powerful little blighters
but noisier at high revs - at low revs they are fine
here is mine shifting 3.5 tonnes of Centaur
D
I have the four stroke Suzuki which has been nothing but trouble, often stalling. A Google search will show that this is well known. Anyone who thinks that these are great motors is welcome to buy mine. FWIW I bought a used two stroke Mariner off eBay and use that while the Suzuki sits in the shed.
the little air cooled Hondas have been... <usual love affair with this rubbish engine removed>
Did it cause problems right from new or did they develop later?
