snooks
which is quite useful if the previous owner got his calculatins wrong, where as if it is a folder it is yet more expense.
Surely this is about buying a new prop, and if you give the correct details to the prop manufacturer, they will supply the correct prop....So it would be if you got the calculations wrong
Flexofold are good, they give you all the measurements of the props so it's possible to make a template to see what size the biggest prop I could fit was.
Knowing I could get a 16" in there if I had to, I changed the gearbox on my new engine to get the biggest prop I could for it, which happened in the end to be a 15" in the end
