jfm
Dunno M. It might not be a scheduling issue though. On D12 you have to lift a tall rocker cover off some long studs, and need lots of spare height above the engine to do that. In sq58, there isn't the headroom clearance. c12 could have a whole different design of rocker cover that needs less headroom clearance for all I know - I'm not familiar with detail on C12.How does the schedule for adjusting valve clearances compare: D12 vs C12?
Remember with a carpeted boat this is a total non issue. you just unpeel the carpet, remove a few screws in the sofa base, and two massive panels lift out of the saloon floor revealing the engine tops. Obviously you swear plenty but it's a straightforward job and you do NOT have to remove the saloon sofa as some Sq58 servicers wrongly conclude.
I remember Gludy posting pics years ago of a Sq58 where the servicers had dismantled the whole saloon and he wrongly concluded that the boat was badly designed, when the actual problem was stupidity of the service team. I wish Fairline had put a sticker on the floor under the carpet explaining how to do it right. VolvoPaul and I did it the correct/simple way ourselves and it was no drama for anyone sensible with an electric screwdriver
