statgar
Thanks for the P46 accolade I totally agree and wonder why I'm upgrading. The SQ55 had an engine less small RIB I guess about 75 kg.
Thanks jrudge clearly there is an issue with the CAN bus system I thought it was just the Pilot system. Located in the lazarette this boat has 2 x 370 ah batteries attached to a big tin box on the port side to which is also attached the aftermarket Victron charger, on the centreline there are 2 x 270 ah batteries, I couldn't see a third battery. Do you have any knowledge of a fix/upgrade for the Energy Solutions setup or does the whole lot have to come out and start again?
Other points noted particularly the last one!
Good to know that there is a fail safe option on the CAN bus system, I am getting a full survey carried out on all the electrical systems as clearly I am ignorant to this boats complexities.
I thought the tin box and its batteries was a 240 v invertor to deal with refrigeration and other AC systems except the aircon didn't realise they used local invertors.
Thanks again for your help can I pm you if I need more please?
