psvpilot59
Hello boat people...
Once a flyer, now with heart bypass, decided to buy a boat! Was advised the 'Fairline Holiday 22' which I bought recently, is a good popular 1st boat, and at the price, no need for bank managers, mortgages etc...!!! However, I would appreciate advice from anyone with knowledge of these boats, particularly with regard to performance, fuel consumption,noise etc...!!! My boat is 1976, so I assume it is a MK1 ? - 130hp Volvo 4 cylinder (AQ130C/270) on a stern drive. Full survey, including engine - satisfactory - with 4 year BSS certificate. (4x200psi on compression test)
1)
@ 5kts - 2400 rpm
@ 6kts - 2600 rpm
@ 7kts - 2800 rpm
@ 8kts - 3000 rpm
@10kts- 3600 rpm.....("This is Maximum revs and speed!!!")
2)
At 3600rpm (MAX) it is unbelievably and unacceptably NOISY!!!
3)
Don't know yet (Till she comes out of the water later this month) what size/pitch the Propeller is, but with it only achieving 3600rpm at max throttle, I believe that to be at least 1,000rpm below normal??? (BTW - Throttle properly adjusted and giving full movement at carburettors, and engine revs freely off the clock in neutral!!!) Is this boat/engine/drive...as fast as it should be? Is the Propeller maybe too high geared, stopping the engine from revving any higher? If the Propeller was lower geared (Finer Pitch) allowing the engine revs to reach their maximum (Around 4,500 - 5,000rpm) wouldn't the NOISE then be off this planet???
PS - Hull...Pressure Cleaned and Anti Fouled August 2001!!!
Thanks in anticipation
LM
1)
@ 5kts - 2400 rpm
@ 6kts - 2600 rpm
@ 7kts - 2800 rpm
@ 8kts - 3000 rpm
2)
3)
LM
