waynes world
Disaster.....but then nah
The boat has gone to Canvasman for canopy to be made. So while its away, dam i miss it haha sad i know but the boat yard ( garden ) is not the same with out it and looks empty.
Had to get a mate to tow it for me as i STILL have not got my licence back yet. Dont ask there as they have really done my head in now after a pone call the other day.
Plan was while its away i will clean up and paint the drive, got my sand blaster and a greenhouse to get tat bit done. Just ave to see if the compressor keeps up, i tried it on a few parts and its ok but not long period. If it struggles to much ill just blast the smaller parts and use elbow grease to the drives.
Well as some mite remember i got a `good` engine from a chap who bough it for a few parts. Apparently is was rebuilt and running well. All happy as when i removed the head to check the innards etc i found new pistons in, well looked new.
I had a wee problem though as one valve lifter was sticky. i sorted that out but was concerned why it was sticking.
Today i thought ok, ill get a list of gaskets/ parts needed and get it all sorted next weekend
NOOOOOO pigin nora and all that. On closer inspection, and dont ask why i did see it sooner
What do you see ?????
wire brush out and
I would of thought the core plugs would of gone but maybe a week spot in the block.
A little gutted but on further inspection i found the pistons are new
These are + 0.020 oversize. and as in good nick and one of the other better blocks i have the bores are .45mm smaller so i will get one skimmed and rebored. Would of homed it out but not risking it for sake of a few hundred quid and the worry when its spinning at over 4000rpm haha
Also the crankshaft is good within tolerances and clean.
So a stress to start but all ended well. But not going to give in. dam no.
Ill need to make a gear puller type tool to remove the cam drive gear to get the cam shaft out, i tried a gear puller but to big on the feet. Ill sort that easy enough though.
C Faffer
wire brush out and
C Faffer
