Fairleads with rollers - who makes them?
Magnum
RIP
14 Jan 2004
Jersey
Anyone know who makes this fairlead or something very similar?
I'm getting some serious chafe with my present open stainless fairleads.
Ex-SolentBoy
25 Nov 2006
If you don't want to mess with the hardware, there is a very high quality commercial anti chafe product called Chafe-Pro. I bought some from the USA. It looks good, and is easy to fit.
Magnum
RIP
14 Jan 2004
Jersey
I have stainless open fairleads and the problem is caused by the angle of the bearing surface. The edge cuts into the mooring line unless it is within a narrow range of angles.
Magnum
RIP
14 Jan 2004
Jersey
If the line was taken straight ashore off the cleat in that picture the fairlead would be redundant. It even looks as if there are antichafe strips on the hull that assume that option?
Yes, but when with lines go directly astern you have to use fairleads or risk damaging your pushpit. The problem (without rollers) is the change in angle from the fairlead to the cleat.
Ex-SolentBoy
25 Nov 2006
Despite lots of preplanning we found that certain mooring configurations created lead angles we had not anticipated with our new boat. These can be in both the vertical and horizontal planes.
Adding rollers can help in some circumstances, but not all.
No matter what you do there will be some movement. You either live with the rope damage, or pass the problem to another material. If you cannot eradicate the movement, you are better off with a sacrificial product like Chafepro.
JayBee
15 Sep 2004
Big ship roller fairleads are prone to damage, usually by bending, seizing up or shearing of the roller pins. I don't have any experience of small yachtie versions, but I would be a bit leery of them. My preference would be for closed panama type fairleads (chocks), with a good all round radius on the bearing surfaces and some Chafe-Pro type protection of the rope as a backup, when necessary.
It is surprising how many yacht fairleads are anything but fair. Same applies to many bow rollers with sharp edged cheeks.
Boo2
13 Jan 2010
