Failed oil pump on my Yanmar 4JH3-HTE?
Thank you. I though you were a bit hasty claiming oil systems didn't have a non-return valve!
There is no non return valve in the pump or the oil ways. Anti drain back "valve" rubber flap in a filter can is certainly not a non return valve in the true sense.
It will be interesting to know what the OP's problem turns out to be.
