External topping lift
Haven't sailed with a topping lift in nearly 20 years.
Boom strut when sailing / reefing etc. Main halyard to the end of the boom when at rest. In 20 years I've never once wished there was a topping lift on the boat....
Ditto, no topping lift. But again a rigid kicker strut, which is much safer as can't forget to set topping lift before dropping tne halyard.
True. Our boom is entirely supported by the lazyjacks, until I bring the halyard to the boom end. We have no topping lift at all. We’d never need to use it to bring anything aboard, obviously, the ‘deck’ is only 40cm above the water
What supports the lazyjack halyard up the mast? Is it through a small pulley out on the spreader or something more substantial on the side of the mast?
I ask because I would not like lots of load suddenly transferred to the spreader
Surely the topping lifts most important job is to hoist boom up and out of the way,traveller way off to either side for unimpeded post sail drinks !?
The boom is supported by the boom strut and kept down by the mainsheet -you just have to be aware not to wind the mainsheet down/in too hard as otherwise it obstructs the cockpit tent but the topping lift plays no part -we could easily dispense with the topping lift -if you want to hoist end of boom up (for what purpose though) then can use main halyard .
It is to a quality block, 500kg break load, each side. Our ‘spreaders’ aren’t namby pamby flat alloy things, they are in fact diamonds, separate from the shrouds, and are substantial stainless steel fabrications, to support considerable pre tension in the diamond stays, a 3 pointed star to support port, starboard and forward wires. There’s nearly a foot of pre bend in the mast, a 8” carbon tube. There’s no doubt they can carry the load, this is a factory setup that has lasted over 20 years so far. Sorry, quote is FUBAR, but for DDB obviously
Selden replied to an email with an image of what they do for Oyster yachts (to reduce the righting arm off the headbox). Perfect solution:
Cheek block and halyard exit.
