surekandoo
Hi all,
My stern gland has developed an external oil leak.
The gland consists of a brass tube with an oil seal at each end, facing inwards on the inboard end, and outwards on the propellor end, next to the flexible rubber tube attached to the bulkead exit through the hull. The space between the two seals is fed with normal engine oil from a small reservoir.
I had noticed that oil usage was starting to increase but not alarmingly so after the boat was launched this year. However on the last trip I noticed an oil slick over the stern when mooring up, and the reservoir was empty.
Obviously the seals will have to be renewed (last done about 6 years ago), and this means haul out, after which the job is quite straightforward. I even have spare seals.
I have a trip planned with a friend on the 25th July don't want to do the remedial work before then, and my question is this: How much risk of internal seal failure and consequent water ingress am I running to do short coastal hops with minimum engine usage?
Also could I ameliorate the situation be using thicker oil e.g. EP90 or 140 in the reservoir?
