External antenna for Digital Yacht WL510
Tim-JS
29 May 2021
I've recently acquired a used WL510 unit, but without cable, mounting stand or antenna.
Does anyone know enough about antenna / cables to advise whether these are always "dumb" and so I could use different (cheaper :) ) brands, or is it possible that the DY branded ones will include some kind of intelligence that will be recognised by the WL510 so I'll only be able to use theirs ?
Thanks, Tim
sailorbenji
20 Oct 2011
Thanks, Tim
We have one on board...the antenna is entirely "dumb" and connected via (I can't remember the spec) basically coax cable.
Tim-JS
29 May 2021
Thanks, that sounds promising.
Will have a look to see if I can fins some alternate options :) .
Thanks again, Tim
Tim-JS
29 May 2021
Thanks for the manual :), from what I can see, the key characteristics i need to find are:
  • For the antenna, I need to have 2.4GHZ
  • For the cable, I need to find LMR400 coax
I've scouted around for used antenna and for brands i recognise... used ones seem to be quite widely available on ebay at around a third of the price of a new "correct" DY antenna.:
Both are omni directional, which I think I need as i currently have an "iBoost Pro D8" directional extender and it's less than great when swinging on a mooring or at anchor :ROFLMAO:.
Of course there are also cheaper unbranded antenna on ebay, but i presume using a brand that i recognise will give me a higher chance of not being disappointed ?
So for those who know about these things:
  • do both of these products look like they should work with the WL510 ?
  • is there anything that should lead me to choose one over the other?
  • will the 9/10 dBi of these products perform (approx...) only 20% less than the 12dBi of the "correct" DY antenna, or is dBi some kind of exponential scale ?
Thanks again.
