SteveA
I intend fitting a monitor/alarm to the wet exhaust of my VP MD2020 engine and would like it to only be powered when the engine is running - has anyone any idea how I can do this?
Thanks but my fuel gauge isn't powered from the engine instrument panel. The md2020 engine has quite a simple panel that doesn't seem to have any constant 12v when switched on - that's my problem.Pick up the 12 volt supply from the light on your fuel guage on the instument panel,
Always "live" when engine is running i.e. power on at instrument panel.
You dont say if you have the panel with a key switch or the "standard" one one with a push on/off power switch. Presumably the latter but in either case you can pick up a switched 12 volt power supply from the red/blue wire in the panel. At the on/offswitch ( or the key switch if applicable) would be the most appropriate place to connect.Thanks but my fuel gauge isn't powered from the engine instrument panel. The md2020 engine has quite a simple panel that doesn't seem to have any constant 12v when switched on - that's my problem.
Vic Many thanks that's exactly what I want. The panel is the simple push on/off switch. I had hoped to tap into a connection at the engine (shorter wire) but will do as you suggest. The monitor is a cheap Chinese job and will have an in line fuse
Look at the wiring diagram in your owners manual for guidance.
It would be appropriate to fit a fuse, suitably rated for your monitor and the wiring to it, in the connection especially if your exhaust monitor is any distance from the engine control panel although as you will see from your manual the supply to the engine control panel is itself fused.
You do not say what monitor you are fitting but I note that a 1 amp fuse is recommended in the supply to the Nasa EX-1
Note the red wire on the on/off switch, or on terminal 30 of the key switch if you have one, is the power to the panel and is therefore not switched.
