Rooster
Have a 90 degree copper exhaust hose elbow directly below the engine which is connected to 2 sections of flexible exhaust hose. One of the joints has been leaking so I decided to get a new piece of hose. The copper elbow has 2.25" (57mm) O.D. sections to connect the hose. So I bought 2.25" I.D. exhaust hose which when clamped with 2 jubilee clips and the engine started, sends a small jet of exhaust water out of the joint. I've rotated the hose but there's still a leak. The copper elbow is not damaged in any way. Is there some suitable sealant I can use for these joints or should I be using smaller diameter hose? If so what size? I know I can heat the hose in boiling water prior to fitting, but access is very restricted and it could take a minute to get the hose from the boiling water to the joint. Also the hose wall is made up with two wire coils. Will heating the hose make much difference? The other piece of flexible hose connected to the elbow is labelled "Volvo Exhaust 828465 41,025a 448641" if anybody knows what I.D. that might be.
Does anybody have any solutions bearing in mind the poor access which makes it difficult to push the hose on with any great force?
Thanks R.
Thanks R.
