NickRobinson
austenitic.....-
No, but it wrote Pride and Prejudice.......
Does that mean it can count cards?![]()
As for your perception of thin wall material being no problem forget it - even 22g sheet can suffer from CP Ref: urinals fitted to one of HM Subs - corroded to hell round the welds - wrong material - 316 NOT 316L.
I'd be interested to know how you knew it was carbide precipitation.
Any metallurgist could answer that for you. A single crack develops along a line in the weld HAZ and nowhere else. It's known as 'knife line attack' because that is just what it looks like. Nothing else will cause it.
It was I that did it, cost me 200 notes instead of 500, kludge it wasnt and i expect it to last far longer than the cast iron one. All the bits were 316, I did all the hard work in sourcing the bits and workshops, doing it again, wouldnt take as long.The PBO article it was just after I had bought a new elbow, having read it I decided that the DIY version was such a kludge that I wouldn't even consider it.
ASAP is your friend. If someone wanted to really do it cheaply they could use schedule 80 carbon steel bits.
Stu
Simple, I was the metallurgist that carried out the failure analysis.I'd be interested to know how you knew it was carbide precipitation.
Thanks to all for your contributions. There's a lot of knowledge and experience out there.
Stu, Thanks for coming on here. I'm swithering about going down your method. After all the water cooled section as supplied by ASAP is designed for the purpose, and any bend and flange that I weld on upstream, is not going to be in contact with hot salt water, just heat.
How hot does the elbow get? And is wrapping it in insulation tape sufficient to stop it radiating excessive heat around?
At present, I think the actual elbow is alright, but the water connection is destroyed, so I have to do something. The water connection is priced at something over £70, but I reckon I could make up something for nothing. It's only an elbow with a flange and a hosetail. Mind you the 2" length of rubber hose is priced at >£14. Where do they get their prices from? I can buy a metre of that for less than half the price of 2"
I really got quite a fright when the water connector fell apart. It's not something which would be easy to jury-rig.
So I may make up a stainless one, using the water-jacketed tube from ASAP, but I may also make up a mild steel one, to lie in the bottom of the locker, just in case. The MS one would just be a simple flange / elbow / pipe, with a water connection welded in, so wouldn't be water cooled. It would probably need to be made longer, so that the water had time to cool the exhaust before it came in contct with the exhaust hose. I'm just thinking aloud here![]()
No, just sillyAustenitic / Autistic - don't worry, Nigella is dyslexic
No "perhaps" to it - have you seen what these matlots drink? FFS it would take the chrome plating off your bumber or use it for descaling your engine.That's the one I have. It's very nicely made and I haven't spotted any rust on it after two seasons, though I am planning to have it off for a good hard stare (and to decarb the exhaust port, if necessary) this winter. Perhaps Clyde seawater is less corrosive than Royal Navy urine?
