Daydream believer
Of course . But how many would get it, "right"?It's possible to do it right, also. Like on keel cooled boats.
I do not have an issue with access having changed the saildrive seal twice. I have changed item such as engine mounts, including an engine mount bracket that broke (50yds from my home berth after, 4 weeks away from home inc motoring up the Dutch canals) I have changed the alternator for service. The exhaust elbow & every year the filters & oil, as well as the raw water pump. I have changed numerous impellors & had the heat exchanger off for cleaning & checking.I'm not impressed with the access to parts of the MD20xx engines - partially the engine and partially squeezing the engine Into a very confined space (the hull at the point of installation is not much more than the size of the engine).
If the deposition is, as I elude, a calcium deposit then the mechanism is a chemical process within the elbow - the calcium comes from seawater (and it maybe a calcium and magnesium deposit). It is difficult to envisage why stainless would reduce this deposition, unless something in the cast iron acts as a catalyst. But if it is a thermo-chemical process then running the engine, not under load, should not make any difference......? Calcium deposition also occurs on the water intake hoses - which you can clear by beating the hoses on a hard surface and then flushing them clean. Calcium and magnesium in seawater is common and in some parts of the world the water is saturated and there is a natural deposition (which would eventually form limestone or dolomite). There are facilities round the world extracting magnesium from seawater or brine - its common place (think Hartlepool between 1940 and 2000 - ish where 100,000s of tons were extracted). Think also of furring of your kettle (in the absence of a water softener).
I made one for my MD22 10years ago from SS threaded pipe parts and an ASAP mixer. Still going strong.Every thread on issues with an exhaust elbow and specifically the MD20 series (but I also believe the newer D1 series) mentions the difficulties of removal and the blocking of the elbow with a deposit, erroneously described as carbon but actually calcium hydroxide or carbonate pigmented with carbon.
The deposit can be removed with acid (proving that it is not carbon) but the acid also attacks the steel or the casting and I have found you can only acid treat once (and it is very messy)
If the elbow did not block there would be no need to remove it - and then the whole issues would go away. Not entirely true as the cast versions do corrode - but they block more frequently than corrode - so corrosion is not a big issue.
Along with the above the other oft repeated comment is to replace the elbow with a stainless version, or which there are a number of entrepeneurs out there making them. A google search also throws up pictures of what look like cast stainless version - identical to the cast iron or steel versions - looking very professional.
Despite the constant mention of replacing with a stainless version I have never seen a back up report suggesting they offer any solutions to the issues of the genuine cast version. The water intake (spigot) on the cast version seems to have a baffle inside, to spread the water? - and this baffle, or its method of attachment does corrode (and many stainless items corrode where there is any welding).
I've just removed my exhaust elbow (another interesting story) but I need to replace the elbow and am wondering whether to go down the stainless route or stick with the original cast version.
Do stainless elbows last longer? do they somehow stop the calcium build up,? are they corrosion free? - basically are they worth the money.
Any background
Jonathan
I have read, on this forum, that part of the problem is caused by running the engine under low load, say to recharge batteries.
Check you don't need the high rise one which is much dearer and not usually available in stainless
I’m interested the gasket John. Is it still available?I’ve got a spare brand-new gasket for the exhaust elbow if you or anyone is interested? It was kicking around on my spares and as I no longer have a Volvo 20 series engine I don’t need it.
Send me your address by pm and I’ll stick it in the post.I’m interested the gasket John. Is it still available?
That is because the 2003 does not suffer from this problem to the same extent plus the number of engines in use is tiny compared with the replacement 20X0 series than ran from the late 80s to 2005 and the D1 range which is still current uses the same design.P4Engines is about 7 day to NZ
Never thought to check AliExpress, but cant find one for a VP2003 anyway.
PM sentSend me your address by pm and I’ll stick it in the post.
I can't answer your question regarding build up of deposits in the elbow but I bought a stainless steel one for my 2001 from HDI Marine in the USA via eBay. Your elbow appears to be available from them but it is more expensive than the Alibaba version. All I can say is that mine was beautifully made and fitted perfectly. I don't use the boat engine enough to comment on whether it will clog in the future or not.
V878 Stainless Steel Exhaust Elbow Replaces Volvo Penta Perkins P/N 861906 | eBay
