V1701
Ask previous owner, maybe he can shed some light?
it seems to me that many posters have put the cart before the horse.
Mast rake should be set up to suit the boat and as said just a little rake as related to the hull water line.
If you find then that the mast base seems to have a high point loading as in the photo you should remove the base from the cabin top and pack the front to give an even load on the base. The cabin top is almost certainly not level so some packing is needed. At the same time check the structure in case it has deteriorated. good luck olewill
The mast doesnt look like the original on a boat that old. It could have been re-masted and given the boats value that could have been done using second hand. Could be the wrong length forestay.
What the OP needs is some sound base data. Given that the builder is long gone, he will only get that from another owner preferably of an original boat. Once he knows roughly what rake is needed / the length of the forestay the rest should be easy to work out.
