Seastoke
They are twins , what will a lake sailer know.I'll ask.
No .So every time a faster boat overtakes you, you turn around almost 180 degrees and head off in a totally different direction just to take it bow on.....
No .
I would turn into the wake of the passing boat
No, bows.So you'd take it on the beam..? Doesn't that just make matters worse?
90deg not 180. And yes I boat on the solent, and yes it is like being a pin ball, especially when then big boys blast past.So every time a faster boat overtakes you, you turn around almost 180 degrees and head off in a totally different direction just to take it bow on, then turn all the way back around to get back on track? I hope you don't boat on the Solent, it must be like being a pinball!
Let me explain. Porto’s photos above is 90 degrees90deg not 180. And yes I boat on the solent, and yes it is like being a pin ball, especially when then big boys blast past.
The difference is that the pointy end is designed to hit the waves and the stern isn’t. Many boats get steered by a following sea
GotchaLet me explain. Porto’s photos above is 90 degrees
It depends on the size of your boat and the size of the wake. A superyacht at speed can put up a terrific wakeIf the stern of a boat can't take the wash of a passing planing boat (they're not Point Break high, and neither are they breaking waves!) whilst under way itself, it probably shouldn't be at sea.
To go along with your salute you need a loud hailer and to shout some obscenities at them ... actually the correct etiquette is to mouth the words silently and see if they can lip read.This weekend we were on our way back to our home birth after a great day out at anchor, we were doing 24 knots minding our buisness when we were passed by a much larger vessel . The boat passed us at approximately 15m on our port side 2 female guests waved as the passed and I returned with a middle finger salute.
The wake from the other vessel was enough that we had to stop to pick stuff up off the floor and put back in cupboards.
We are new to boating and the wife is still a bit uneasy on a choppy sea so this really upset her and it wound me up enough to want to chase him down and knock 7 bells out of him.
What is the etiquette on passing other boats out at sea?
When owned my Last boat We would cruise anywhere between 30-40 knots but would still look behind every minute or so and especially when going to make a marked change in direction. knew there we not many faster boats in the Solent but there are a few,I can honestly say in 6 seasons I have never been overtaken .Bit like an eager virgin I,am waiting
I even crept up on this , gave it a wider birth and slid by .![]()
He started to speed up to 30:knots was cruising at 28 , so I called him out and eased up to 34 , he folded and sat in my wake .
Probably $hat himself when he glanced at his L/ Hrs exceeding 1000 trying to keep up .
Get a boat that cruises at 30 knots …end of problem .
