spudnukem
Active Member
Westerly fiberglassed over every nut. Shudder. Long screw and mole grips every time!
My answer has always been to tap the thread in to GRP for bolt. Screw it down then tighten a nut against the GRP from under neath. No good if the hole is already clearance but you could try filling the hole with epoxy then drill and tap.
One other trick might help is to file a flat on the end of the bolt. So that if you can get the nut on over the flats you can hold the tip of the bolt while tightening the nut with spanner. ol'will
Wish I'd thought of that....I screw the bolt down, leave it with a ring spanner attached locking it in place with a length of cord then go below, put on the nut and ratchet it tight.
