Captain Sillyboxes
Active Member
Hi all.
I've never used epoxy resin before but needed to make a minor repair to the plywood rudder on my wayfarer - I'd removed a section where the water had got in and prepared a replacement piece of marine ply which fitted the gap. I'd also sanded down a few damaged areas and intended to paint a layer of epoxy onto these before revarnishing.
My local chandler gave me a small amount of epoxy and hardener in 2 Styrofoam cups with instructions to mix 2 to 1, I don't know what brand it was.
For the replacement patch I mixed a few ml, estimating the quantities by eye. Three days later in a warm room and the excess from that batch was still tacky so I assumed that its never going to cure, maybe judging ratio by eye was not good enough. So I removed my clamps to try again only to find that the patch has set rock solid. So in this case, the small amount clamped between two parallel wooden surfaces cured while the excess didn't.
Second attempt, this time to paint a layer of it onto the damaged regions. I took no chances and measured the quantities with a syringe to get exactly 18ml mixture, which came to just under 1cm deep in a plastic yoghurt pot. It was ~25° where I was working. 5 mins in and the resin in the pot started bubbling in an exothermic chain reaction, giving off so much heat that I couldn't hold the yogurt pot. A couple of minutes later and all the glue in the pot was rock solid, frozen into strange bubble shapes like an oversized version of the inside of a crunchy bar but not edible. The resin that I'd painted on before this happened seems to have cured rapidly but not so fast that it bubbles.
Seems a bit of a learning curve, does anyone have any insights as to what I did wrong or is it just a case of needing lots of experience to do it right?
