Epoxy fillers for cheapskates
Not sure if that is a response to my post, but I suppose so.
If so, thats different, being a rust inhibiting spray, rather than a paint with "filler", a la thread title/topic.
I have used motor oil thinned with diesel or white spirit as a rust inhibiting spray on vehicles. Latterly i added vegetable oil to the mix.
I wouldnt use sump oil on road vehicles, since its teratogenic, carcinogenic, a skin irritant, might be acidic, and isnt necessary since a little fresh oil goes a long way. I have generally crawled under my vehicles and fiddled with them a lot, so I wouldnt want that stuff all over them..
I MIGHT use it on timber if I could avoid skin exposure (say in the bilges of a wooden boat, or on rubbing strakes) where its probable antimicrobial effect might be of value.
I CERTAINLY would not spray it.
In particular your requirement to use diesel sump oil "full of carbon" doesnt make much sense to me since as I understand it carbon's electrochemical properties will tend to encourage corrosion, though the oil may still have a net positive effect on corrosion, (relative to doing nothing) as might the relatively high TBN of oil for diesel engines.
I suppose the carbon could just barely possibly keep a thicker layer of oil next to the steel
All I can say is it stopped several Ford Transit chassis from rusting on the inside. I cut a piece out of one chassis when I was scrapping a vehicle and the metal was like new. I go by what works !!! If it works I keep doing it.
That may be why me ould mother dosed me up wi' cod liver oil when I were but a nipper - and I'm still here.
Not according to Owners Clubs and others that I knew and LR'd with ..
I once had a tour of the factory, near the end of the Defender line there was a leak test stand, they sprayed them with lots of water. My how we chortled as the No 1 question was "If they don't leak straight off the line, do you fix them so they do?" :ROFLMAO:
I daresay it does
But, as I already said, that doesnt even slightly imply that fresh oil wouldnt work as well or better on steel, and it is a lot pleasanter and less dangerous to work with.
You are talking a different model LR .....
The engine oil into chassis frame was with the old Series 2 .. 2a machines ...
