raro3
Hi all, just looking for advice on my current project. I've had the hull of my Vancouver 34 sand-blasted to remove the anti-fouling build-up. There is no trace whatsoever of osmosis, and the blasting revealed that she appears to have been copper-coated below the waterline at some stage in her life. I'm now planning to apply 2 coats of Jotun Penguard HB two-pack epoxy primer just to provide an additional barrier, followed by one coat of Jotun Vinyguard as a tie coat / primer prior to anti-fouling. All to be applied with good quality roller, and I'm assuming I don't need to sand down the entire hull prior to application - the blasting left it fairly smooth, apart from a few small areas which I've attended to.
Does this all seem reasonable, and are two coats of the Penguard sufficient, given that she already has an old copper coating? Any advice would be welcome - I don't plan to do this again, so I want to do the best job I can. Thanks, Phil
