Slow_boat
EPIRB and PLB seem to transmit the same information on the same channels so are we better off with one boat EPIRB or a PLB each?
They serve two different but related purposes which is why they are both offered. Which you choose depends on how you perceive the risks. EPIRB locates the boat, or literature if you take it with you. Desirable if you sail out of VHF range as a means of notifying rescue services. PLB also locates but on a personal basis so arguably more useful for locating an individual in the water.
So they are complementary devices, not perfect substitutes. For offshore work an EPIRB is of more value but PLBs have been used successfully in MOB situations.
EPIRB batteries seem to last 5 yrs whereas the McMurdo Fastfind battery lasts 6.
I think I must be getting old because I don't understand this. If an EPIRB and PLB do essentially the same thing but the McMurdo Fastfind PLB battery lasts a year longer than a typical EPIRB's battery then why isn't the McMurdo Fastfind PLB a better option to have onboard?
Why on earth should ultimate battery life have any bearing on the matter? Do you intend being in the water for 5 or 6 years? Read my explanation. The two devices serve different but related purposes. In coastal waters an EPIRB has little or no advantage over a DSC radio. Offshore it is the most practical way of alerting rescue services. The PLB as its name implies is a personal device intended to locate a person in the water.
So no, they do not do the same thing although they use the same technology. If they were interchangeable then only one product would be offered, the other would be redundant.
You will see from other replies that people make different choices dependent on their needs, and of course many boats will have both.
Looking at the blurb, it appears that an EPIRB transmits for 48hrs, a PLB for 24hrs.
I would have thought that if you're not rescued within 24hrs, you're pretty well stuffed anyway.
We also went for two Fastfind PLB's which are carried on our lifejackets. We also have the Lifetag system. It's worth bearing in mind that PLB's need to be manually deployed and then held with the antenna upright. An EPIRB is automatic IIRC and will float with the antenna up.
EPRIB = largish, floating beacon, designed to be utilised when a boat sinks or crew takes to liferaft. One per vessel, make sure you attach it to the liferaft if launched.
PLB = small, not always floating beacon, sending same info as EPIRB. Designed to be a personal item, carried at all times. It aims to locate an individual in the water. Can be used in the same circumstances as an EPRIB. Generally, battery life ONCE ACTIVATED is less than that of EPRIB.
There is a case to be made for carrying both on a boat, several PLBs to protect the crew in the event of MOB, one EPRIB to locate the life raft after a sinking. However, for most folks, PLBs are the best compromise. We have 2 PLBs, one on each of our life jackets. Our cruising is a mix of coast hopping and two to three day passages in the Med.
Thank you for the explanations of the differences. Now I understand. I think on balance PLBs would be the better option for us.
Those explanations are no different from those that I gave so don't know why you had so much difficulty in understanding.
I can see no extra benefit of a typical EPIRB over the much cheaper, longer battery-lasting, McMurdo Fastfind PLB.
