alexincornwall
Hi all,
I've been using Epifanes Rapid Clear for quite a few years - it suits my amateur wood coating skills and general lack of time/patience. Have never experienced a problem and have always been happy with the results - until now...
I have recently removed my oak companionway steps and brought home for a little freshening up. They weren't in bad nick but the leading edge of each step was showing some wear. Not entirely sure which product they'd been varnished with as the last coating would have been before my ownership. Anyway...
Attempt one -
Brand new tin of Rapid Clear, stored at room temperature and shaken/stirred thoroughly
Sanded back to almost bare wood with 80 grit on an orbital/multi sander
Finished with 240 grit
Vacuumed thoroughly
Used a tack cloth to remove any residual dust
Applied one thin coat of Rapid Clear
Allowed to dry in our extension (ambient temperature probably 20 degrees C)
The stuff just would not dry. Rapid Clear claims a re-coat drying time of 5-6 hours which I've always considered optimistic but not a million miles off. 24 hours - still very tacky, 48 hours - not much better - 72 hours, still tacky. Decided against coat two as I wasn't liking what I was seeing. Recounted my steps and concluded that the only thing I'd done differently was use a dedicated tack cloth. Decided that the cloth must have contained something that the Epifanes didn't appreciate (it was quite... tacky).
Attempt two -
Removed coat one using white spirit applied with a cloth
Allowed to dry thoroughly - tackiness and varnish virtually gone
Started over, this time with 180 grit, which took it back to almost bare wood. Chose 180 grit as I considered a little extra key might be useful
Followed all steps as per attempt one, minus the tack cloth and used a damp microfibre instead
Reapplied coat one - even thinner this time
18 hours later - still a little tacky. Nowhere near as bad as attempt one but why isn't this stuff drying? Epifanes recommends against thinning down the first (or subsequent) coats but I'm beginning to wonder. I'm half tempted to simply crack on with the next coats, put the steps somewhere peaceful, warm and dry and leave them for a week or so, but my better judgement tells me that something isn't right here.
Any ideas please?
Attempt one -
Vacuumed thoroughly
Attempt two -
Any ideas please?
