david_bagshaw
A long shot...
have you checked the throttle/ governor lever moves when in gear?
what happens in reverse?
#14The engine revs freely without the resistance offered by the prop (in neutral). The engine is managing to turn the prop, but not as fast as you would like, and you can't turn the propshaft by hand. Sorry, but the prop/external shaft is either fouled or damaged. Try to keep engine use to a minimum and dive on it as soon as you can to confirm the problem. If you're lucky it's just fouled and you can clear it with hand-tools.
Before condemning the injection pump and removing it, get yourself a small container of clean diesel and pipe it directly to the fuel intake of the injection pump, a priming bulb in the fuel line would make things easier. Then try the engine. Yes fuel will return to the main tank and not your temporary container but it will give you enough time to determine if the pump is at fault. You may have symptoms of fuel starvation, using the container will take the fuel supply and filters out of the equation. Also some pumps may have a small wire gauze in the intake pipe at the injection pump, take pipe off and have a look, you probably don't but just to make sure. If you can't get a priming bulb just pipe it without one, the dpa has its own supply pump.
A long shot...
If the propeller shaft turns by hand easily and if the engine revs when out of gear then I suggest that you check the gearbox.
Check that the two pipes from the injector pump to the CAV filter are connected the same on both your engines.From memory the two pipes back to the filter was the standard 1.5 system with a restricted bleed off the top back to tank
Jim
there should be a return line from the filter to the tank, any excess going down this line.
There is no such line. Don't understand that! Does that not mean that the lift pump is delivering in vain? In from the pump straight back to the tank?
Anyway, I have taken the bleed outlet from the injector pump straight back to the tank and the engine will now rev in gear. I have not done an open water trial as I am on the canal and the wind is stiff. I don't want to take out a bridge by drifting down onto it - it is frowned upon.
I shall report back to the pump rebuilder today and see if he can explain the difference.
Sounds like there was air in the system?
