oGaryo
Hi again, for those that can recall waaay back, I was looking to get my first boat in the winter just gone by but due to financial 'negotiations' I've had to downgrade my aspirations for this year and instead of getting a sportcruiser I've purchased a 1998 Bayliner 1750 with 3.0l inboard.. + a no expense spared trip to disneyworld for the family + a pair of tickets to wimbledon quarter finals for me and my lady :-( The latter two being the reason for lack of coffers this year.
The guy who sold it to me let me know it had been laid up for two years on his drive and would need an engine and drive service.. however, he showed my the engine running, albeit roughly.
Got it home and it's gone from trying to start (engine splutter's) to cranking over but not starting at all, doesn't even try to fire up now.. I've done some diagnostic work checking the battery, plugs, distributor cap and the like and have fixed a few obvious things like removing the crud off the points in the cap, cleaning earthing points and giving the plugs a clean..
I think I have a fuel supply problem from the carb to the engine.. can someone confirm please before I go buying a kit to service it (or putting it in for a service more like along with the engine and leg).
The reason why I think this is that I get a good spark at the plugs, cylinder compression is in the green on my compression gauge, I get a squirt of fuel (two jets) in the carb intake when I pump the throttle so supply to the carb looks ok but when I turn the engine over several times and look at the plugs immediately after, they're not wet with fuel hence suspecting I have varnish or particle blockage within the float chamber and ducts feeding the engine. As there's no sign of fuel getting to the chamber's, I'm not suspecting poor fuel condition yet but it's likely it'll need changing I guess even if the engine was running a few days prior to my buying the boat.. finally, I can smell fuel after cranking the engine which I suspect is the carb float chamber flooding as the fuel has nowhere to go due to some blockage on the engine feed side of the system.
What's your advice please.. strip the carb down or are there further checks I should make first before dismantling it? e.g. even though the switch on the throttle is set to 'run'... could that have a dodgy connection?
by the way.. it's a mechanical fuel pump by the look of it (no wires going to the pump).
loving this boating thing already LOL taking a cup half full outlook, at least this boat's enabling me to learn loads about the mecruiser engine before parting with some serious cash next year on a bigger boat and it was running a few days ago so the rest of the engine is likely to be ok.
cheers Gary
cheers Gary
