Firestone
What size engine and type of gearbox is necessary to navigate the Thames against a strong flow comfortably???
What size engine and type of gearbox is necessary to navigate the Thames against a strong flow comfortably???![]()
I am looking at an 60ft X 12ft 6" steel barge for liveaboard cruising that can be handled by 1+ crew. What if any benefits are there to having an AZIMUTH 360 deg prop over a shaft driven prop.
I assume you're thinking of the arrangement used in Valhalla, where I think it's hydraulic and there's more than one (4?), giving the boat the ability to crab sideways. sounds fab! Very expensive. Come to think of it hasn't "the Royal Rowing Barge"got at least a pair fitted?
The advantages are:-
pretty well total manoeverability.
The engine can be placed anywhere and gives more scome for power generation as well
Quietness in motion
The disadvantages are:-
Cost
You'd be in a minority of two (AKAIK) in that size of boat - so not a lot of expertise
The props: will be quite exposed, so you have to be very careful when mooring on the Thames and even more so on the canals. A conventional single screw is protected by the hull / counter overlap and is of a more substantial construction.
Do some googling, but I'm talking about the widebeam version. The NB one was the owner's first attempt.
Bother, I wasn't going to get involved
Thanks to all for the shared information. My concern in using an Azimuth would be the limited canal passage of certain broad beam canals and their depth or lack thereof.
