We have a long keeled sailboat with a new engine (Nanni Diesel 21 HP). Exept for the charger we only use 12 V onboard. The engine has no zink in it. We have no ground plate outside the hull. I therfore wonder: Should we connect the engine to the shaft with a cable ? (There is a plastic coupling between the engine and the shaft).
I would be greatful for any advice - thank you in advance !
Sanna
(from Oslo)
Sanna
(from Oslo)
