xeitosaphil
Now looking at it more closely in response to your specific question I begin to see the snags, if snags is the right word.
As you have drawn it ( nice big clear diagram on my computer BTW) with the house battery charger negative connected directly to the battery negative the ammeter will not see the charging current from the house battery charger .... BUT ... here comes the hiccup ... if the VSR is a dual sensing one, and I think you said it is, as the battery becomes charged the VSR will close and the engine battery will also be connected to the charger. The engine battery charging current will then be seen by the ammeter as a discharge.
Moving the charger negative connection to the other side of the shunt ( to the negative stud) will solve both issues.
If you use the engine battery charger instead, although you now have no ammeter to show the current going to the engine battery, when the VSR closes the current going to the house battery will be shown correctly by the house battery ammeter.
On the fuses issue. Don't fit fuses larger than necessary to supply the current to circuits connected to them....... that may mean you can reduce the size of the fuse in the feed to the distribution panel possibly also in the winch circuit but the winch maker may reccommend a fuse size large enough to carry a high initial current
As far as wire sizes go they should always have a max safe working rating greater than the fuse supplying them ... so that in the event of a fault the fuse will blow before the wire overheats and sets fire to your boat.
In all but the shortest of cable runs the wire size will probably have to be greater, much greater even, than the max safe working rating in order to control voltage drop. The longer the cable run the heavier the wire will have to be.
Vic,
Have amended my diagram as suggested for the house charging negative.
One thought - if using both the mains chargers to charge the different batteries at the same time, and the VSR being bi-directional , will that mean I will have to isolate the VSR as the chargers will be in conflict with each other! I would probably have to turn off the ammeter as well as it would register both combined charge rates would it?
If this is necessary if I put the switch back in the VSR negative will it isolate the VSR when using the mains chargers? I might in that situation forget to turn it back on again as someone previously said.
It might be better for me to loose the engine charger all together as it seems it is causing some trouble. What do you think?
On fuse issues- all noted, ------ all circuits on distribution panel are correctly individually fused for equipment anyway.
On Cable runs- can I just run this past you
My house batteries to isolator- engine starter and return negative to battery is 8.2mtrs.
My engine start battery to isolator – starter and return negative to battery is 6.5mtrs.
My Lofrans Windlass is fed from engine battery – winch and return negative battery is 14.5mtrs
The winch cable at present is 35mm2 and all battery cables are 25mm2
I thought I would change all the starter battery cables for 50mm2 which I thought would be ok?
The windlass seems to be ok cruising last year but I only use it when the engine is running, and only in short burst not continuously.
