LadyInBed
Have you dismissed a 1GM10? It's the same block so same weight and fittings.I was looking at re-engining a prospective 28ft boat from a 8HP 1GM to 16(?) 2GM.
2.5 increase in hp as 1GM is 7.5hp.
Hopefully I'm going for a 14HP Beta.
The online prop calculators suggest 7 knots flat out, which is more than plenty, but hopefully gives confidence of sustaining over 5knots in adverse conditions when the weed has started to grow?
Do people think that is about reasonable?
I don't know what prop you currently have, but some people go for a 2 blade folding prop to reduce drag when sailing at the cost of motoring performance.What should I look on the prop? Higher efficiency?
What on the gearing?
1982 I bought a 33 ft Nauticat which had a Perkins 72 hp diesel. Which I beleived was about right.What differences or impact would have a sailboat if its engine is replaced for another one with increased horse power?
I don’t think speed would be too much difference from 20 HPto 36HP on a 28 foot boat as this would be limited by the hull speed.
Are there any advantages at all if installing a more powerful engine, or not really?
I was using 1GM vaguely, meaning any variant. Wouldn't a 1GM that's not a 1GM10 be pretty old by now?Have you dismissed a 1GM10? It's the same block so same weight and fittings.
Not necessarily. A good three or even four blade folder can have more thrust than a three blade fixed prop. Our Brunton three blade folder has move thrust than the one it replaced. In reverse it's less efficient than a fixed prop. It's about careful prop selection.
Mine isn't a variable pitch. That would be the Brunton Auoprop. Mine is a Varifoil. It's a three blade folder. The blades on my folder look like Mickey Mouse's ears. Lots of area?Agreed. The Bruntons is probably an exception due to it's ability to change pitch. Never tried, just looked at it, so no direct experience. The surface area for the diameter looks less than a fixed - how does it perform in a sea? Does the variable pitch make up for the loss in area? Or is it that say a 14" fixed is replaced with a 15" Bruntons - ie is it a direct comparison, or is it better only if you have the space for a bigger one?
Me. My engine destroyed itself because it was no being driven hard enough. I re-powered with an engine rated at half the hp, and I can't tell the difference (other than it being quieter and cheaper on fuel). The rated hp is not the whole story though. My old engine was rated at 105hp, but that was at 4,300rpm. Nobody drives a boat engine at 4,300rpm. I used to cruise at about 2,000-2,500rpm (at 2,000rpm the engine was only producing about 30hp).Who ever complained that their boat's engine was too powerful? Too heavy yes, but modern engines are nothing like as heavy as the traditional old lumps, unless you had a Dolphin that is!
I replaced my old Centaur's MD2B with a variety of engines, but the last one, a VP2003 at 27hp-ish, was far and away the best choice. I now have 50hp in a 34 footer, but would quite happily have something 50% more powerful as it gives the power to punch into anything without fretting about over stressing the motor.
Modern multi cylinder engines are definitely the way ahead too - Far less stress on every element of the boat, though I do miss the comforting old thudding.
The worry about under-stressing the engine is, IMHO, grossly exaggerated. But then maybe I have a leaden left hand.![]()
Was your first engine turbo charged?Me. My engine destroyed itself because it was no being driven hard enough. I re-powered with an engine rated at half the hp, and I can't tell the difference (other than it being quieter and cheaper on fuel). The rated hp is not the whole story though. My old engine was rated at 105hp, but that was at 4,300rpm. Nobody drives a boat engine at 4,300rpm. I used to cruise at about 2,000-2,500rpm (at 2,000rpm the engine was only producing about 30hp).
I replaced it with a 50hp unit, which even though rated at half the hp, had a cylinder capacity 10% bigger than the old one (so 10% more torque), and the max revs are 2,800rpm. I now cruise at exactly the same speed at between 1,500-1,900rpm and it feels no different to the old engine, but actually has more "snap" and grunt in close-quarters because of the extra torque.
So when choosing an engine, don't just look at the hp figure. Look at the power curve and the hp at the revs you will cruise at, and look at the cylinder capacity, as there's no substitute for cubes.
Yep, my engine is 86hp. Maximum torque at 1200rpm. 4.4litre spinning a 22" prop. We cruise at 6kts at 1200rpm in flat water@3.3l/hr. Maximum revs are 2000rpm. We are over propped. Theoretical max revs being 2400rpm.Me. My engine destroyed itself because it was no being driven hard enough. I re-powered with an engine rated at half the hp, and I can't tell the difference (other than it being quieter and cheaper on fuel). The rated hp is not the whole story though. My old engine was rated at 105hp, but that was at 4,300rpm. Nobody drives a boat engine at 4,300rpm. I used to cruise at about 2,000-2,500rpm (at 2,000rpm the engine was only producing about 30hp).
Diesel van and car engines seem to have very long lives, spending most of those hours running at a small fraction of their max power.I was always told by salty old engineers that diesels like to be run hard. Unless there's reason to believe your boat is significantly underpowered, then I'd leave well alone. As others have pointed out, there's a lot more to consider than horses alone, and the interrelationship between all the different parts of the propulsion system is quite complex.
Hi Tranona,Broadly speaking a 20hp will be fine up to 4.5-5 tonnes which could be a heavy 33' or a light 36'. 30hp covers a very wide range of boats from 33-38' ( up to 7 tonnes) when the 40hp takes over as standard. Length is not a particularly good measure of size nowadays with short overhangs and wide beams. My 33 (10m hull length) is the same displacement as the 37 it replaced (hull length 11.7m) and has the same size (30hp) engine.
The original question about whether a new, more powerful engine is worth having is really not the right question - or rather does not have a simple answer. Older boats were often under-engined, either because it was not the "done thing", or cost, space or even because there was not a suitable engine available. Many older boats benefit from having a more powerful engine than the original and also gain from more refinement, greater reliability, freshwater cooling allowing hot water etc. However this comes at a cost, often high in relation to the value of the boat, so the OPs choice of a recon engine of the same type is a viable alternative if it has adequate power. Downside is having a long obsolete engine with all the future worries about spares - and to be frank older style engines particularly saltwater cooled do not last as well as modern engines. Don't think to will find many who have replaced Bukh 20s with a Beta 25 or similar regretting their decision!
Old one was 2.0 turbo/intercooled. New one is 2.2 normally-aspirated.Was your first engine turbo charged?
There might be more truth in what you say for a seawater cooled engine which doesn't get properly warmed up at low power?
Does it apply to a modern freshwater cooled Kubota engine?
Surely those digger and generator engines run all day, most of it at light load?
