Tim O
I live aboard and currently my engine is out of action due to faulty injector pump so i cant run the engine to pull an antifreeze solution through
The raw water system still contains some freshwater from its last use - would the best solution just be to drain all this out from the lowest point......i figured if i remove intake from pump and the hose from the anti-syphon break at highest point, then blow it through i can basically remove the majority of the water.
The coolant system should be fine as it has antifreeze in anyway.
So far i havent bothered as its not been so cold and Im onboard with heating on most of the time but may have to be away the next two days
