Glyka
Hi,
I used to leave the engine's sea cock always open, until a month ago a friend of mine had to lift his boat off the marina's bottom.
Since then I always close all sea cocks when leaving the boat and have twice ran the engine dry! The last time (yesterday), for about 20 mins. (I hadn't read the excellent idea of leaving the engine keys by the sea cock!!!). I started the engine, performed a place change manoevre (ordered by the marina HQ), left it running until all mooring lines were correctly set, and swiched it off, happy for my perfect move. Half an hour later a (very big) bell rang. Sweating all over, I checked the sea cock and found it closed... Without any thought, I opened it and started the engine. Oddly enough, after a couple of seconds water started to flow from the correct point (the exaust, that is). I switched the engine off, closed the sea cock, left the boat and went home where I could think and cry undisturbed.
The question is: what might the damage be?
The engine is a Yanmar 3HM35F (fresh water) with about 1000 hrs. What I think could be seen as sort of good news is that the fresh water circuit is passing trought a water heater that is usually full of cold water.
I haven't been to the boat since, and I would appreciate any ideas on what to look for (other than the impeller that I will replace anyway) when I will feel brave enough to face my engine.
Thanks,
Theodore
Thanks,
Theodore
