Seastoke
So when to start engines port engine tried slow then clonck, so dipped oil bevlow dip but dip is only half inch tolerance so put 2 litres in back to top so tried to start again slow to turn but started and sounds like it is missing then a lot of black smoke and picks up revs an d is running fine so off we go for the wknd three hour cruise at good speed no prob only a bit smoky so 2 days later same slow to start lots of smoke then runs ok ,no not batteries as does both engines so I has a look at engine and found fuel pipe was seeping diesel now it seems to start right but with smoke , QUESTION COULDTHIS LOSE PIPE CAUSE MY PROBLEM AND COULD IT STILL CAUSE SMOKE AS THE PIPE MIGHT HAVE GOT AIR IN TO GIVE WRONG MIXTHNKS FOR REPLIES PS ENGINE PERKINS 225 350hrs
