oldmanofthehills
Hardly a con. The point is not that sophisticated oils might do harm but that they are a waste. They are designed for engines that are totally different from our simple low powered engines. You don't need to go into the technicalities but logic says that an automotive engine that produces 2 or 3 times the power for size of engine, runs at 50% higher revs and has to cope with a duty cycle that includes high load cold starts, periods at idle, rapid acceleration and long high load runs needs a different type of oil than a yacht auxiliary that runs most of its life at half power at constant revs and temperature.
Exactly my point. People are struggling to find suitable oil for elderly diesel when a readily available modern might do just as well.
